In any transformer, the applied current generates a magnetic flux, some of this is used to magnitise the core, (search for magnetic saturation for an explanation) this is generally understood using a b-h diagram, and means that some of the input is lost in magnitising the iron core - this is Lm
In addition, some of the flux generated, actually misses the core, - it finds its way from the north pole of the winding to the south pole of the winding without going through the core, or through the secondary winding - this magnetic loss is Lp.
In addition, not all the flux that goes through the core actually goes through the secondary winding, - this is the Ls
- If you reversed the primary and secondary windings, then you would be able to measure the Ls just as you might measure Lp when not reversed etc.
So a core made up of poor magnetic material would increase Lm, and a core which has a poor design such that the magnetic field from the primary doesn't all go through the core would increase Lp, similarly if the design is such that the secondary doesn't link well with the core - this would increase Ls
