S
Shaun_H26
Hi all.
Can someone point me in the right direction for the current regulations on control panel isolation for machinery (industrial) if possible please?
An issue arose with a machine trapped key system failing, allowing an individual to remove the key, but the machine staying live and running.
It was discovered that the trapped key isolation mechanism had failed allowing it to be turned off for the key to be removed, but not disengaging the electrical breaker mechanism unfortunately.
My concern is that the trapped key system is being used as a separate supply isolation system rather than being incorporated into the existing safety system (PILZ etc) so if it fails, there is no redundancy.
Any help much appreciated !
