Discuss Tricks for pulling wires in the UK Electrical Forum area at ElectriciansForums.net
@Pete999 you can't change your avatar. It's been like having the head teacher looking over the class - don't make me start a vote to reinstate Pete leaning against the kitchen counter with his birthday Tshirt on.
Done and dusted I'm afraid. But thanks anyway, I was fed up of that one anyway.
Cable sock on the end of the cable rod. The cable being taped to the side of the rod could be hitting the edge of the hole. Using the sock allows the cable to travel through the hole in the same route.Super Rod Super Grip Cable Connectors Pack 4-15mm 4 Pack - http://www.NoLinkingToThis/p/super-rod-super-grip-cable-connectors-pack-4-15mm-4-pack/9302K?kpid=9302K&cm_mmc=Google-_-Product%2520Listing%2520Ads-_-Sales%2520Tracking-_-sales%2520tracking%2520url&gclid=CJby65jZ7dMCFQ5mGwodH5UGVQ&gclsrc=aw.ds&dclid=CM-AoJnZ7dMCFewh0wodhZoDmg
I assume that this is in a house I would take floor up rather than make holes in a ceiling unless it is being all re-plastered as no matter how good made good you can always see the difference.
Do they never let go? I would always feel that a little bit of tape was needed 'just in case'!
Reply to Tricks for pulling wires in the UK Electrical Forum area at ElectriciansForums.net
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
