driverJohn
Hi do tt earth systems highly require a rcd, and if not are upfront rcds a must in the tt earthing systems? Cheers
My concern is that there is apparently considerable uncertainty about whether this installation would disconnect under fault conditions as opposed to sitting there with live metalwork ready to kill someone.
From the questions asked I don’t think we are going to be able to reliably guide the OP to an answer.
This could be a life or death matter and as DPG said the installation really needs looking at asap.
I've seen TT installations where a fault meant live metalwork - not a fun situation.
yeah true but the lucky man here got earth leakage circuit breakers, but its kind of disappointing to see that as all the pipes are connected with the earth and under a fault condition not all current flows to the elcb as some goes to the other pipes and most luckily they have lower impedance compared to the breaker.
Without any intention of causing offence I believe that you have a very poor knowledge of requirements for protection against shock and I strongly advise you to get an Electrician in for safety's sake.
Without any intention of causing offence I believe that you have a very poor knowledge of requirements for protection against shock and I strongly advise you to get an Electrician in for safety's sake.+
Well i do both part time dentist and electrician
Email
Time zone
Last seen
TT earthing enquiry.
driverJohn,
DPG,
