Discuss UF controller connection to boiler in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Dodgy
Hi All,
I have a wundafloor 3 zone uf heating system and a separate rad system running off a Baxi Ecoblue Advance heat Boiler and Megaflo tank. The rad system runs fine via a Danfoss controller but the installer has not wired the uf controller to the boiler so the uf cannot "call" for heat and only works when the rad system is already running. I've connect a twin cable to the two terminals in the uf controller and would appreciate if someone could advise on connection at the boiler end.
Cheers
Reply to UF controller connection to boiler in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
As a young man, I was an electrician, but now I'm getting on, I am strictly DIY. I used to have a cheap old 900W petrol generator connected to a...
Hi. We are looking at installing a Wiser smart heating system inc. trvs We are currently electric only, with normal rads and a Heatrae sadia...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
