Discuss UK downlighter fittings in the Lighting Forum area at ElectriciansForums.net
Hi,
Been looking to replace a set of downlights that have seen better days. Been doing some checking of what's in place to see whether it's just a swap them out and come across something I wanted to ask about. Power at the fittings is 12v AC so I've looked in the loft and there is a transformer fitted which I assume is changing line voltage down to 12v for the old fittings. Is that assumption correct on the face of it. If that's enough to go on
When checking what I am looking to fit they have a transformer integrated into the fitting. As such before I waste time and money, will a 12v at the fitting supply be enough to power a 220-240v supply rated fitting with built in transformer. My gut feeling is no it won't work
I'm already thinking I will tap out and get a professional in but we struggle with availability round here for little jobs.
Thanks in advance.
Just to add that, as you would be modifying a lighting circuit, you would need to make sure that the circuit is protected by a 30mA RCD.
Reply to UK downlighter fittings in the Lighting Forum area at ElectriciansForums.net
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
details 12v outdoor fairy lights 20m in length, coaxial socket UK 240v plug that with built in 12v 1amp transformer 220v-plug/12v-transformer...
