C
Chris Electron
Posted this in the heating section earlier but didn't get a response. Any help would be great. Thanks.
Hello,
I recently attended a job where the underfloor heating programmer/ thermostat was broken. When chatting to the wholesaler to find a replacement he warned me that I would have to get the same make and model as the one that is broken. This is slightly annoying as I will have to order it instead of buying one that is in stock.
Could anyone tell me please if it is true that you need the same model? If so why is that? If I found one which had a similar load (in this case 8A/ 2kW ish) would it not work? Is it something to do with the probe not being compatible?
Any help with this would be really appreciated.
Thankyou,
Chris.
The Probe/sensor would have a specific ohmeric value. This value changes as the system gets hotter and eventually it gets to the value that switches off.
You would need to see if the one you found as that compatible value to the existing sensor
Thanks. And apart from the probe and rating is that about it for difference between the makes and models? Am I simplifying this too much?!
I can only assume your programmer/thermostat is just a glorified switch.
It may be an all singing all dancing switch that switches at different times, it may switch different zones at different times but a switch never the less, and so if it load rating of the one you found is capable of switching the load then that is fine.
It is the thermostat and sensor/probe side with that value which is really important as if it's the wrong values the switching on/off will be at the wrong temperatures.
I have to admit I would be trying to source like for like as your wholesaler recommends here. Remember if you do put an equivalent and it only 1% out of compatibility, then you maybe going back and forth a lot with the system not working exactly as spec. Sourcing equivalent parts for me personally is when the original can not be found due mainly to the age of the component and non availability
Chris Electron,
malcolmsanford,
