Discuss underground cable joint in the UK Electrical Forum area at ElectriciansForums.net
H
hooman68
for reducing ac resistance in EHV milliken type cable, the strands should insulated by using enameled strands.
I want to install underground large cross section milliken type cable with individually insulated strand.
I don`t know what accessories i need to remove enameled coating from each strand.
would you help me to know how should i do?
and what kind of accesories for these purpose i need?
I changed it to mentor.
What do you mean when you say your a Mentor?
Can you clarify your level and experience so our members can tailor there answers appropriately, can you also clarify the voltage you are working with here as EHV can be different depending which standards and industry your in
An enamelled cable is going to be 1,000mm² or more, so we are talking about a serious termination. I don't have experience of terminating large HV cables but I think one can safely say that experience is needed and careful study of the manufacturers' instructions for the termination, which will be matched to the cable (an enamelled-strand cable is physically larger than a basic Milliken sectored cable). They will probably offer much more specific information than we can on a forum.
Reply to underground cable joint in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Hi guys, I'm trying to find a definitive answer on the use of 1.5mm 2C+E for power points in a transportable structure which is fed by a 15A inlet...
I have a fuseboard change I need to do soon I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD My only concern is how I should run the pyro cables in...
I am an enthusiastic retired engineer rebuilding a barn in France from scratch and am having problems sizing my incoming electrical cables. I have...
