Discuss Underground cabling to garage. in the Industrial Electricians' Talk area at ElectriciansForums.net
DavidIT
Hi,
I have a garage in a block just outside my back gate. I wish to supply power to it but am concerned with the regulations regarding cabling across communal ground.
My garage isn't attatched to my property. It is about 6 feet from the boundry of my garden. The land that the cabling would have to cross under is communal i.e owned by all of us using the garage block.
Can I legally cross this land to power my garage?
Hi,
hi,
i think legaly you do not have the right to cross the ground ,at least not without the other owners aggrement ,and then you could negotiate wayleave, as it would be noted on the respective property deeds ,by a soliciter, going ahead without could be classed as damage ,so be carefull ,your local council should be able to advise you ,
a right load of crap for 6ft of cable ,but unfortunately ,i think thats the way it is
good luck:)
I have the same problem except my house is 2 years old and on a private development. The only way I could get power to it is via a high level catenary wire but looks too ugly so I have to make do with no garage power.
Reply to Underground cabling to garage. in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
