Deleted member 144471
Hello. I know there are a ton of posts on this subject but I still can't figure it out... I have two three-pole light switches (one in the garage and one in the living room) that I can't figure out... When checked with a multimeter, they both show only 10volts... When checked with a circuit breaker finder, they both go to a breaker in a basement bedroom (however even when turning off this breaker, they still show a few volts on the multimeter). I have tested every outlet (top and bottom) and they all work regardless of the position of the switch. It is really throwing me with the low voltage coming across vice 0 or 120... I am not the original owner but they have never worked since I have lived in the house (not sure about the previous owner). Any assistance you can provide would be awesome. Thank you.
Unknown Light Switch
DIY Electrical Advice
Thread Tags
Deleted member 144471,
James,
