Discuss Up loading photos in the UK Electrical Forum area at ElectriciansForums.net
Easiest way I found is to download the photobucket app, upload them to that then post the link here in img tags.
Photobucket is good as are many of the others but there can be a problem. If your photobucket account is not used for a certain period of time or you "move" photos within your account then the photo will no longer display on the forum.
Once you have uploaded your images using the forum uploader you have the pictures at your fingertips which is good if you think you may post the picture more than once.
:thumbsup
Reply to Up loading photos in the UK Electrical Forum area at ElectriciansForums.net
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
Can anybody ID this brand, I've been sent the picture only, as another "electrician" has been and butchered it and tried to fit mk grid, couldn't...
