Discuss Use of backup power supply in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Richt16
Hi world of knowledge
I have two gen 1 x 5kw hybrid inverter, with batteries. My question is can I connect the two backup out put via 2 isolators and 2 rcbo then combine them into one input in to a 100amp auto switch in the main cupboard outside so if grid goes down I would have 5 kw backup to the whole house via the main fuse board I will also be adding couple of 8ft earth rods to connect to the TNCS incoming point thanks in advance 👍👏👍
Reply to Use of backup power supply in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi, Recently had 3.6kw solar installed, at the time shortage of batteries & roi figured batteries not quite worth it. thinking otherwise perhaps...
Need some advice, I have 7 static caravans to connect which need to be connected via TT 1. All the vans have a 30ma RCD main switch internally...
