This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
E
elliot123
Currently wiring a boiler but the pump is inside the boiler ? My connections in the boiler are L E N RT Im guessing rt is room thermostat? Or have I got confused the boiler is a valiant ecotec plus 637
RT is the stat switched L.
No manual plumber must have took it with him, so if I wired from the boiler with a 5 core flex, taking L E N that being a permeant live ? from wiring centre then used the black in the 5 core from the oranges on my wiring centre to the RT connection at boiler that should be correct?
