Discuss Vauxhall Vivaro goes limp in the Auto Electrician Forum area at ElectriciansForums.net
There's also a massive difference between something you drove 20 odd years ago against its more modern equivalent.
"I dont like X make of car because the one and only time i ever drove one, it had a rattle" Therefore, every model of that make must be rattly!
You can also get a new car, that is just a lemon. Every other one, same spec, same age... and there's always one or two that has "something" wrong with it.
I think ive owned just about every make going... or at least drove one.... and i dont think theres any that i would say I'm never having ever again
Once bitten thrice shy.
They have investigated, replaced the turbo boost pressure sensor, manifold absolute pressure sensor, vacuum pump, vacuum breather hoses, crankshaft position sensor, inspected the turbo (no play or leaks). Then they sent the ECU to be tested and they said that "components have beed deleted, van had DPF and EGR delete".
Wow, someone has been playing a nice game of 'parts darts' at your expense!
Have the DPF and EGR been physically removed from the vehicle? Or have they just been deleted from the ECU?
Parts darts 🤣 love it!
Unfortunately a lot of places seem to do this these days instead of actually finding the real problem!
For larger jobs we skip the darts and go straight to the 'parts cannon'
It does seem to be the trend with mechanics, plumbers ( the self professed 'boiler engineer' type) etc
Just saw this and wondered why anyone would want to make their van look like a Turkish Dolmus?
Which raises another question... Turkish minibuses are almost exclusively Mercedes Sprinters - do they get a more reliable version of the Sprinter in Turkey? Those things are on the road all day, every day in extreme heat and never seem to miss a beat, yet no one over here has a good word to say about the Sprinter's reliability.
I used to regularly drive a couple of Sprinters (2005 model). They were both permanently fully laden at just shy of 3.5t and, despite the particular model being woefully underpowered for the weight, and so flogged hard, were surprisingly reliable. Started to rust quite quickly though...
Reply to Vauxhall Vivaro goes limp in the Auto Electrician Forum area at ElectriciansForums.net
Right so after weeks of my 2.0ltr vivaro randomly losing power and going into limp home mode it has now decided that it's going to do it all the...
9K
My customer read on many forums about people suffering to solve a problem with the above Land Rover with regards to a fault code known as P1260...
29K
