Discuss View image at your own discretion in the UK Electrical Forum area at ElectriciansForums.net
What is a gigmatic explosion?What wound anyone recommend to repair the exposed single insulation from the thermo plastic conductors on x14 electrical meters?
Code 2 on EICR due to storage of goods in a large room might bash into the basic insulation and cause a gigmatic explosion.
Is there an insulating material to use?
Either drop the meter onto the trunking, or fit some containment around the cables.What wound anyone recommend to repair the exposed single insulation from the thermo plastic conductors on x14 electrical meters?
i'd modify that slightly. screw trunking lid to wall, then with suitable "u" shaped cut-outs for the cables, clip the trunking onto the secured lid. (this is where the hammer comes int play).Just put a short section of trunking between the meter and the existing trunking to fill the gap, if installed lid to wall the lid can be slid behind the tails and the trunking clipped over the top.
Reply to View image at your own discretion in the UK Electrical Forum area at ElectriciansForums.net
