Discuss Vokera linea 24 Nest install in the Central Heating Systems area at ElectriciansForums.net
Hi all,
I have a Nest stat, heatlink mounted and has a 4 way & earth connected with a separate 2 way connected.
2 way to go to wall stat T1 & T2 12v from the heatlink.
Earth to earth
Heatlink L to L on boiler
Heatlink N to N on boiler
Question is 2 & 3 on heatlink ( i think are supposed to go to TA TA ) on boiler can someone confirm and can they go either way round.
Currently the TA TA go to the old wall Stat (still connected until I'm sure which way round it needs to go)
Cheers guys
If the two TA terminals current have the thermostat connected between them then yes you would remove the existing connections and connect the nest terminals 2 and 3 to them. It's just a switch so it doesn't matter which way round they are.
Thanks for the quick reply, to confirm I have realised it's not both TA connections it is the Top one which is = and the next one down which is TA.
Attached are 3 photos
1. Nest diagram 2 & 3 used.
2. Vokera terminal block diagram.
3. Actual photo of current active connections.
I'm presuming it's still the same no 2 and 3 from heatlink to the = and 1st TA terminal to replace the 2 that I will take out.
Cheers all.
[automerge]1586186572[/automerge]
Forgot to add attachments.
Reply to Vokera linea 24 Nest install in the Central Heating Systems area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
