Discuss Voltage problem. Help. in the UK Electrical Forum area at ElectriciansForums.net
S
Si Voodoo
Hi all,
Been to fit a new bathroom lamp. LED type.
Light is very dim.
Voltage between Live and Neutral is 103 Volts.
But between Live and Earth it's 203 Volts.
Any ideas what would cause this.
I'm going back to get into the loft tomorrow and see what's happening.
Previous electrician did a runner and would not come back and fix the bathroom light.
So why the reduced voltage between Live and Neutral??
Thank you.
Simon.
Basic testing of the lighting circuit cables would be advisable. Maybe the sparky has wired it so that your lamp is in series with another? Do some R1+R2 testing. And confirm L-N and L-E back at the CU. Were you testing with an MFT?
Thanks.
Didn't have time today, but will go back and do thourough tests and trace out this circuit.
I just used a Metrell voltage tester.
Will take the full kit tomorrow.
if it's the last light on the circuit and all the others work OK, then the fault will not be far away.
by arthur conan doyle... the case of the missing volts... available in paperback. £ 5.99.
Reply to Voltage problem. Help. in the UK Electrical Forum area at ElectriciansForums.net
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
