Discuss Voltage Stick Advice in the Electrical Tools and Products area at ElectriciansForums.net
I didn't edit the post as such, but you debunk one but not another
I haven't 'debunked' any product, but simply highlighted issues that may arise when personally importing goods of unknown quality, which are poorly advertised.
The other indicator is from UNI-T and, while I can't comment on it's reliability, I see no reason to question a product which is manufactured to known standards, by an established company and sold through a distribution network that bears a measure of responsibility to ensure it is fit for purpose.
Is there anything else I can help to clarify?
After you looked them up, you mean
Obviously, you ensured the one you have promoted complies.
Interesting. According to UNI-T, the product is discontinued, but as you have discovered, is available on ebay from chinese vendors. Looks identical to the one I have.
Perhaps you can tell us all about what standards non contact voltage indicators should comply with, how to ensure that a product does comply with said standards, and what dangers physical or legal could result from using a non compliant product.. Because I haven't a clue, and I couldn't give a monkey's.
Question passed to nicebutdim.
If that's what I'd meant, I'd have posted as much.
UNI-T are a fairly well known brand, albeit at the budget end of the market, with some of their products offered by a well known UK distributor of electronic products - no need to look them up. What I didn't realise, and didn't look at due to it being a known brand, was the fact that these are sold on ebay from China (as @Pretty Mouth points out). These may be old stock or they may be counterfeit, but buying directly from overseas means you bear sole responsibility for any issues which may arise from the product. As such, I wouldn't be inclined to reccomend buying any voltage detector from overseas, unless the manufacturer offers a global warranty.
I've no idea what standard non-contact voltage testers should meet, which is why I haven't suggested any.
What I did refer to was 'manufacturing standards', meaning quality control. I even made an effort at clarifying this with the comment "Perhaps they're great or perhaps quality varies wildly from one to the next".
I can definitely say stay away from the LAP ones (normally good advice these days generally).- When the batteries get low the torch works, but the voltage detection bit doesn't - or rather it does, because the power light goes off because of the drain, rather than the end glowing red as is meant to happen - so if you know how to intrepret it then maybe it just about meets its requirements.
Fluke 1AC has never let me down and haven't yet had to change the batteries in a couple of years of regular use. It also flashes while on so you can be sure it is powered. But any of the well known brands such as Martindale, Kewtech, Fluke, Megger, Di-Log, TIS, etc should be fine.
Seems they even do proving units for them now, if you really want to go belt and braces, though that seems
According to the instructions, my Fluke 1AC complies to:
Complies with EN 61010-1 2nd Edition, EN 61326 EMC to 1000 V CAT IV
Complies with UL61010, CSA C22.2 No. 1010-1
but no idea what requirements that means it meets....
The Dl-Log 107 seems a decent price, and has variable detection down to 24V - and complies with EN 61010-1 EN 61010-2-030 EN 61326-1 EN 61326-2-2 LVD & EMC (for what it's worth without having copies of all those)
I have a battered Fluke 1AC. I've looked at several of the newer options from different manufacturers, and some have interesting and useful features, but that old Fluke has never let me down and I'm comfortable with how it works.
Having just looked at Fluke's data sheet for the 1AC, I note that they list several standards to which it is manufactured.
Edit: I see @Dartlec also looked at that data sheet while I was typing 😄
I'd looked at the Martindale NC4, Megger VF5 and Dilog DL107, which all work in and around the same range of voltages. Maybe some day I'll buy that well priced Dilog indicator, but today is not that day.
Reply to Voltage Stick Advice in the Electrical Tools and Products area at ElectriciansForums.net
