Any cable joining method,has a degree of longevity built in,to it's reliability under normal conditions,and reliability when abused.
Wagos are a fine product,and are obviously best employed with thought,care and attention to the environment they may be enduring,for the lifetime of the fixed wiring.
Used in the above manner,i believe they are an asset.
Flirted in,willy nilly,because they are quicker than spinning a terminal driver,is as dangerous,as any other poor working practice :)
Twisting cables together and wrapping in electrical tape has less impact on the environment as the costs associated with the manufacture of Wago's means a polar bear will die tonight.
but how many horses die to make the glue on the back of your sticky tape?
I use the non sticky stuff you must have seen it in the past as when you pick the cable up it falls off.
That troubles me...but i can live with the guilt,if it is the particular bear,that has been wiping it's feet on my mints,all these years;)
...and if we are not to waste resources any further,we should organise a bbq...just don't eat the liver :eek:
