Discuss 'warmup' electric underfloor roll out heating matts in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm about to start first fix and have just been dumped with the job of providing power for about 5 roll out underfloor heating matts in 5 different rooms. Whats the usual way supply power to these? Is it best to take power from the ring main or independent radial circuits or install another ring circuit? ..... the customer would also appreciate it to be fast and cheap....as usual. any help appreciated! thanks
What are the power consumption of the heating mats?
3x 500w 1x400w and 1x 600w
there's 3 to go on 1st floor and 2 to go on ground floor
So 2.5 KW to be added to the total loading of a RFC if it was me I would run separate circuits, may be even a small CU dedicated to the UF Heating, over cautious? but that's my take.
To add to my last, although I don#t like to do this you could always fuse each mat down via a FCU off of the RFC, but you would still be interfering with the RFC loading, not sure this way is safe enough but I personally think my first way is the one I would opt for
agree with pete. a new radial for the mats in 2.5mm. 5A FCU take off for each one, alongside the stat.
FFS - they want you to 1st fix for 5 x underfloor heating systems, plus presumably checking the matt after install and connecting up the systems on 2nd fix.
If they can afford 5 x under floor systems, charge them the proper rate!
And yes a dedicated radial is probably the best way to go.
Reply to 'warmup' electric underfloor roll out heating matts in the UK Electrical Forum area at ElectriciansForums.net
Conversation developed with a middle aged lady who has recently lost her husband. Note to self, stop walking dog around the graveyard Anyway...
Hello Guys, I was wondering if any of you nice chaps could lend me some advice. So I have an open vented heating system with a 3 port valve...
