do you plant the trees in the drum or bonsai in the soap tray?
Dont be facetious, they are little mustard trees we plant in cotton wool on the window sill.
[automerge]1575314998[/automerge]
Wot about just using the washing line, to hang the wet washing on
Because, due to the vapour pressure of water, lack of wind and of direct sunlight there are few physical effects that will actually cause the water to volatalise.
And the missus is bone idle, good job she's a looker.
[automerge]1575315365[/automerge]
F17 indicates a problem with flow rate of the water in to the machine - the inlet valve to the condenser - the flow rate is too slow. It could also be the condenser inside is blocked/restricted with lint and fluff.
Bosch Washer Dryer WVD24520GB/01 F17 error when drying - https://www.justanswer.com/uk-appliance/81uvz-bosch-washer-dryer-wvd24520gb-01-f17-error-when-drying.html
I only know about these codes because last week our WM displayed E18 meaning the drain filter was blocked
Ah, sense. Well unfortunately this is a Hisense not bosch
There is little physical indication that the valve has opened although the winding resistance is in range and there is 240V to it.
The water exiting the machine is cold when the machine pumps it out so i dont think its a water/condenser issue, but could well be wrong.
Anyhow the F17 coincides with the high temp trip going.
[automerge]1575315508[/automerge]
5 months old? Send it back. Years warranty, surely.
This will be the case in the end but it winds me up that we have had two "engineers" out to it and they were both clueless.
