Yep, if they're worn down so only just touching it might turn with no load, but not when loaded. Would be a bit of a coincidence if it had just failed though but worth checking.Will that make a difference top quark?
Discuss Washing Machine Won't Stop in the Electrical Appliances Forum area at ElectriciansForums.net
I have a problem with our washing machine not stopping as well.
She just keeps filling the damn thing up with clothes and using it continually
Hi Simon, Your machine's symptoms are a common Indesit/Hotpoint problem. It is caused by a faulty heater element. The wash controller won't change cycle to rinse until the set water temperature is correct, so it goes on washing cold indefinitely because it never sees the water temperature correct signal. You can verify this fault by setting to '11' (Quick Wash) and selecting 'No heat' on the front panel. The machine should complete the cycle. This is useful if you have a washing load that has sat in waste water for while as it allows a full cold wash. If this test works confirm the diagnosis in the usual manner by disconnecting the element, first test element resistance between heater terminals it should be in the region of 20 ohms if good, and then IR test between either heater terminal and the ground tag, if
Hi Markie.
Seems you have hit the nail on the head. Im going to make a double check and put on a wash with no heat on normal setting. If that's the case the rest should be pretty standard to find out
Hi Simon, Your machine's symptoms are a common Indesit/Hotpoint problem. It is caused by a faulty heater element. The wash controller won't change cycle to rinse until the set water temperature is correct, so it goes on washing cold indefinitely because it never sees the water temperature correct signal. You can verify this fault by setting to '11' (Quick Wash) and selecting 'No heat' on the front panel. The machine should complete the cycle. This is useful if you have a washing load that has sat in waste water for while as it allows a full cold wash. If this test works confirm the diagnosis in the usual manner by disconnecting the element, first test element resistance between heater terminals it should be in the region of 20 ohms if good, and then IR test between either heater terminal and the ground tag, if <2M ohms replace the element. A new element for this model is approx £25. See link below:
Indesit Washing Machine Element
Reply to Washing Machine Won't Stop in the Electrical Appliances Forum area at ElectriciansForums.net
