Discuss Washing Machine Won't Stop in the Electrical Appliances Forum area at ElectriciansForums.net
SimpleSimon
Anyone help me with this one please? It's my own washing machine, last night the cycle just went on and on and on and didn't stop on slow spin, eventually had to turn it off but when I turned it back on and tried to Start the cycle again, same thing. There is a load in there, anyone know of any solutions?
possibility of a blocked pump. water won't go so stops the cycle from going forward.
I've got a pump our function on the dial. It's a good shout as when I tried to pump the water out in drained from the drum but wouldn't finish and unlock the door. Hmm easy to fix?
Isolate from power
Gain access to top and rear of machine
Remove top (the machine that is, not your's :) )(screws at rear)
Reach hand down front and release door catch (easier said than done but not impossible, try pulling the cable attached to the lock)
Mop up water from floor
Remove smelly clothes (they may be a bit rank by now)
You may then be able to investigate blocked tubes etc as others have suggested
I take it the machine spins ok? Whilst not impossible, this is more likely to be a blocked pipe than an electrical problem.
I've had the pleasure of sorting a mine (hotpoint washer / dryer) this week and this is what I did.(same problem as yours, wouldn't pump out water and kept spinning) On the front at the bottom ( you may have to remove a plastic trim or skirt if it's built in).
Simply remove by turning (have a load of towels at the ready) and twist off. You will get the whole drum of water out here. Depending on what model you have try and remove any lint or just general cr*p you find in the filter. On ours there is a pipe running from the washer into the pump and it's hard to get to. What I used was a length of net curtain wire, with hook and just keep fishing out anything blocking the machine. I have children and I don't know how, but I've found coins, hair clips, marbles and a small car. Other than that, I am not sure.
Good Luck Anyway
I have a problem with our washing machine not stopping as well.
She just keeps filling the damn thing up with clothes and using it continually
I hope you treat her properly for all this effort she puts in keeping you and yours nice and clean. She deserves no less than the top of the range steam iron and matching ironing board for when the clothes are dried.:shades_smile:
Cheers.........Howard
mouse.jpgwhich reminds me. just bought her indoors a new mouse for her computer
Well lads I emptied the front filter yesterday but still nothing. It worked once when I went through a dry run. (ie no load or detergents.) but than put the clothes back in and it was just the same. Over and over. If I put it on a separate rinse and spin it will drain and also if I pump it out. So I'm really not too sure now Olof it's electrical or plumbing. :/
Im thinking the PCB is broken. :/ trouble is, with about £80 just for the part, and it may not be right. It's not much more to get a comet guy out for the trouble. Grrrr I hate it when I can't solve things. :banghead:
Reply to Washing Machine Won't Stop in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
My 9 year old ISE 10 W256W (ASKO WM70.1) stops at 4 minutes from the end on the Everday-wash cycle. I've drained it with the tube (not much came...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
Hello everyone. I've bought a second hand Bosch series 6 (2 years old, minimal use). The first washing went without any fault during the cycle...
