Discuss Watchdog and Smart meters in the UK Electrical Forum area at ElectriciansForums.net
Who benefits from a smart meter?
the smart leecy suppliers, of course. or do they. m=i=l just had a statement. overpaid by £360 on monthly DD. BG reduced payments by £6 / month. so we rang up and after a lot of argument, managed to get them to send a £350 repayment. better in her bank than BG's.
And also gives them the ability to disconnect you without gaining access to your property I have heard.
Reply from SmartEnergyGB Enquiries when I asked about remotely switching off the supply. Sent them a few questions beginning of last year.
With respect to remotely switching off energy supplies, please be assured that consumers are protected by exactly the same strict regulations that currently protect them against an energy supplier switching off or disconnecting their gas or electricity supplies. This protection remains as strong with smart meters, as it was with traditional meters.
This is also a bit of what I got from the Department of Energy & Climate Change.
Consumers will have control over who has access to their data, apart from where this is required for billing and other regulated duties. As part of the data access and privacy framework, suppliers will be allowed to access monthly data for billing purposes. Customers may opt out from allowing suppliers to access daily data, or opt in to allow suppliers to access half-hourly data. Suppliers will be required to explain clearly to their customers which data is being used, for which purposes, and what choices the consumer has about this. Thus, if a consumer has opted in to giving the supplier access to half hourly data, then the supplier will be allowed to collect information covering half hourly periods.
Energy UK has published a Data Guide which explains which data will be accessed from the smart meter, for which purposes, and what choices customers
i see a sudden glut of phone calls... " hello, this is XXXX co. calling. we can see you're spending YYY /month for leccy. we can save you ££££££s on your bills. switch here to save.".
Reply to Watchdog and Smart meters in the UK Electrical Forum area at ElectriciansForums.net
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Was helping a friend out and changing their CU which had a date stamp from 1990. Good quality Merlin-Gerin unit and a nice job originally. They...
Good afternoon all, I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem. SSE...
