Currently have an electric water heater plugged directly to a 220 outlet. Code requires a disconnect. Will the plug suffice or do I need to install a separate disconnect?
Also if I install a diconnect can I leave the receptacle in place or do I have to remove it and hard wire the disconnect direct to the supply?
