Discuss What do we need RCDs fit anyway... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Shorting out the RCD for continued operation is something I wouldn't have considered as a method of providing a safe electrical environment for the clients...
Do you know why it might be dangerous? DO you drive a vehicle with wheels or legs?
Just to clarify. This is how I found the board, not sure if my sarcasm came over correctly in my post. I hope no one thinks I was suggesting this was actually my remedy.
I have put a new RCD in. It is a temp fix as it is not a Volex RCD as I’m struggling to find a source for a Volex brand? Can anyone suggest a compatible brand or should this be a complete board change if Volex no longer exist (surely not tho?)
I would not have done any temp fix with a non compatible device.
I do a lot of call outs for estate agents etc. It's impossible to carry every make, model and size of RCD/RCBO/MCB on the van and sometimes a replacement is 7-10 days away. Would you leave a property without power for 7-10 days, or fit something that fits safely in as a temp fix?
The reason we don’t mix and match compatible components in CUs, is because we lose the 16kA type tested breaking capacity.
If the individual breaking capacity of the individual components is greater than the PFC, there is no reason why they can’t mixed and matched.
In this particular instance the components have already been mixed and matched, so the 16kA type tested breaking capacity has already been lost.
As such adding another component to the mix will not make the installation any less safe and will improve safety by providing RCD protection to the sockets.
Reply to What do we need RCDs fit anyway... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
