Discuss What do you lot think to this one?? in the UK Electrical Forum area at ElectriciansForums.net
I think rather than writing out a report in a letter I will fill out the Electrical Installation Condition Report form and put the photo's with it and see what happens. I phoned up our Napit inspector last night and he said just fill the form in and back it up with the photo's but take it to a far end of a fart and list everything. :)
Good plan S.I, when you've done you should post the EICR on here for everyone to have a good laugh at how much it failed by. Then publically hang the sparks involved off the whitby swing bridge - if it doesn't fall into pieces by then :38:
but this is it....you dont waste time going through each circuit on a board like that...just fail it all....
then give him a price for remedials...
look, i`m not in the habit of just failing stuff here n there...far from it....in fact i will look for any way i can (as far as is reasonably practicable) to pass an existing install...or if its a case of a bit of tidying up here n there..then so be it...a (3) if you like...
but that board is a load of old b0ll0cks......
most of the other stuff can just be resited outside the zones....
I agree with this one, Bit of a waste of time testing everything. Its a fail regardless
Reply to What do you lot think to this one?? in the UK Electrical Forum area at ElectriciansForums.net
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
I've just stumbled across the below elsewhere online, anyone aware of it? PRESS RELEASE: ELECTRICIAN’S GUILTY PLEA OVER REPORT SIGNING OFF...
6K
TLDR: is there a legal requirement to have a landlords supply to power an L2 alarm system? Mornin'. Non-electrician, under the cosh from an iffy...
