Guest viewing is limited
instalation should be tested certified and completed then Em lighting test carried out to make sure they are all working correctly
As Risteard said Put into sevice
If you want the long winded lawyer type definition
this from
Wikedpedia
The process of assuring that all systems and components of an emergency lighting system are designed, installed, tested, operated, and maintained according to the operational requirements of the owner or final client
what does commissioning mean?
Electrician Talk | All Countries
bluesky,
Flakey,
