Discuss what drill bit? in the Electrical Tools and Products area at ElectriciansForums.net
A
andekoch
what drill bits do you guys use for making holes through floor joists? eg flat, auger, forstner etc
Also has anyone used a '3d' or multi angle drill bit (MAD), they look like they can do a variety of things such as making holes in joists?
Auger every time. None of these fancy 3 or 4 bladed one's either. I had an expensive set, and they lasted about 2 months before the whole set was blunt. At least with a good old fasioned single one you can re-sharpen it several times without much hassle.
Reply to what drill bit? in the Electrical Tools and Products area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
A friend of mine is looking to have an electric shower fitted and has floorboards up already (mostly, long story). Anyway there is a run of 2.5mm...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I can't find a previous thread on this topic, so here goes. There is one sort of house-brick that I dread encountering in my area - they are...
Hi guys I need to put a chandlier in my siblings house. I've taken the old one off. As you can see in the pic. To put the bracket on do I just...
