A
atkins_1
Hello, I've just been looking at electricfix online for an extractor fan to go on the wall in a wet room, nothing special, small room one shower, wall is about 6 inch from inside to out(timber frame outbuilding) . There is so much coice of fans and prices are ranging from £20 but I don't know what fan I need to be looking for. Can anyone shed some light on performance and the basics that are required for a normal size bathroom...?
Here's the link for choice
Extractor Fan Bathroom - Search Results | Screwfix.com
Cheers
For the average domestic bathroom a 4-inch (100mm) through-the-wall fan is usually enough. Depending where you site it in the bathroom you may need to consider a 12V rather than a 240V fan. How you control it can vary and can affect which model you buy - you can have them switch on and off with the light, same but with an overrun so it keeps extracting after the light has been switched off, or on its own switch, either an integral pull switch or a separate one. If you get a fan with an automatic shutter that will stop the wind coming through that 4-inch hole in the wall, or make sure you fit a gravity-shuttered outside grille.
You'll also need a length of 4-inch drainpipe or similar to go through the wall between the fan and the outer grille.
Re price: Buying the most expensive doesn't always get you the best, but buying the cheapest usually gets you the worst. ...
PJ
I always use humidistat fans given the choice, this prevents a build up of moisture if you forget to turn the fan on,ie during daylight, if you have windows and the room is bright. The price vary hugely so that will depend on your budget.
Ben
airvac unity from midshires elec.
Any extractor fan will do - as said above if you want one with a humidi stat then great but they are more expensive, if you only want a basic unit to come on with the light and go off few mins later then get one with a timer. If you want a cheap one to come on with the light and go off with the light then there you go.
they also have kits on there as well for £30 with everything you need except the iso.
Just to shove my two penneth in, I always try and stick to Solar & Palau, they are very well made, totally silent motor and they offer some of, if not the best extraction rates on the market, a market of which they are leading by a country mile! Not hugely pricey either. And if anyone tells you to buy an iCON, tell them to pi$$ off!
I have personally fitted two, they caused me untold amount of problems. Constant revisits, replacements etc... I have spoken with other sparks about them and they have all had the same probs. Bad batch, maybe. Design over function, probably.
Strange, the iCON ones are all we have fitted in new builds for the last 2 years (unless customer requested otherwise). Other than one timer module we haven't had a problem.
Nah gotta be the good old aidelle loovent everytime! Think they're on the mk3 version now.
