Discuss What instrument do you suggest for 5-10Kv at 2ma? in the UK Electrical Forum area at ElectriciansForums.net
T
The Ghost
I was thinking a cheapo electric fence tester but need two probes for avian discouragement track. I have to test volts after installing. Oh and it's DC by the way.
Used to be able to get meter shunt units to connect to the input of a standard multimeter to enable kV readings. Bet you can still get similar things.
meter shunt units
Shunts for high current, multipliers for high voltage.
I use the Fluke 8k40 DMM HV probe, the Testec HVP40 is cheaper. But are you saying you need to measure between two points both of which are at HV wrt. gnd? That's harder. I'd probably use two ordinary ground-referenced HV probes and take a differential measurement between them on the LV side.
we used to call them bobbins. dependent on the internal impedance of the meter, the bobbins had values where you knew what the VD across them was.
Doesn't look like they've changed much over the years those high voltage probe adaptors. Not much you can do to modernise something like that really from a design point of view I suppose! Functional and safe.
Take care to get correct bobbin/multiplier +meter combi.
Meter input impedances are rising !
(or peculiar scale factors are round the corner )
(Higher ! ,unlike DMM I gave my son ,measures 1M and 450k on AC--(all ohms))
What's avian discouragement track?
Bird scarer
what's wrong with a wet finger?
So long as it's yours...nothing whatsoever and I do mean on the voltage just in case you were wondering.
So this is an adhesive track sort of like a railway track and I am measuring between the two tracks to ensure 5Kv is present. When the birdy lands, well you can guess. It is the same principle as the electric fence a pulsed (1.3 sec) burst of 5Kv at 2 ma.
Reply to What instrument do you suggest for 5-10Kv at 2ma? in the UK Electrical Forum area at ElectriciansForums.net
Has anyone here got experience of doing a soil / earth resistance survey for the design of a large-ish site? We might be looking at a fenced area...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
