The SI prefix M is Mega.
In combining the prefix with the unit name, the prefixes' final vowel is retained, except in the case of “hectare”. The American National Standard* also calls for the spellings “megohm” and “kilohm”, but the spelling “megaohm” is often encountered.
Megaohm or Mega Ohm or MΩ
It should never be truncated in spite of what the US does.
Things end up with different meanings, for example
1 millimetre is 1mm or 0.039"
1 mil is 0.001" or 0.0254mm
So giving a dimension as 156mil - is that really what you mean? Something around 5/32"
Annoys the hell out of me as insulation (dielectric breakdown) is measured in both V/mm and V/mil and people will say air is 3kV per mil - no it isn't you muppet air is circ 3kV per mm or 100V per mill (it isn't a straight conversion!)
It’s an insulation resistance meter, combined with a continuity meter, and nowadays performs earth loop impedance and rcd operational tests.
Some might call it a multi function tester….
Others still call it a “meggar”
As for the measurements taken… it’s Megaohm
Like megawatt, megaton, etc
