_q12x_
- I am a bit 'new' to using self alone ADC's; ... I used it as integrated function of a PIC, I read about it, I have a general idea as one does, but using it as a stand alone chip, I Never. So...forgive me if I was a bit hasty or jumpy or stupid when encounter NEW concepts like this. For me this is a new territory. Very interesting territory actually that I will get into more depth... but it remains in a todo list. Not right now. Right now I am putting on the table the cards that I consider important. So... I get into digging on wikipedia and I opened 3 pages: [Analog-to-digital converter], that lead me to [Gray code]. And a 3rd one very new to me, I never heard of it [Flash ADC].
Mister @marconi here (I've almost write Tarcone, like a mafia boss name, haha, but you are not far from one, right? hahaha - little joke). You first introduced me to the [Gray code] concept actually in your last project which I avoid it since it was completely new to me. But you also give me the lecture about it, and I also read on wikipedia myself back then. But now, scrolling and reading lightly in ADC page, to refresh my memory about the principle, the rotary encoder using [Gray code] jumped on me, like that. And is excellent ! - This means, I will certainly build one and play with it. Again, not right now, now I am putting on the table what is important. Making some plans and speaking my mind. From my understanding, [Gray code] is exceptionally used for rotary encoders, where you get only one possible code all the time, whiteout uncertainty, while rotating between the values, or as wiki says more elegantly : "between two successive values differ in only one bit". I want to believe it can be adapted to a device that is not rotating like a potentiometer does, but something like a LDR or termistor. Very fascinating subject that remains to be dig in.
- Another interesting 'card' on the table, is future addons to my board. One addon that I will surely built immediately after I finish all these IO boards, for security reasons only, is a string of transistors for a safe and secure Output drive. I will probably use BD 139 because I already have 100pcs brand new. I will probably but unsure yet, I will build a string of mosfets but at this chapter, I only have very small, smd mosfets like my A09T
, which is a N-Channel and possibly A19T which is a P-channel. But they are very small and not so powerful. My greater wish is to have more powerful mosfets than those, to drive some serious loads. It will probably remain to do it in time, in the future,when I will have access to such mosfets, but for sure, the next step I will add those BD139, because I have them and are powerful enough. I want more powerful than them , but like i said, in time. So this is my security plan for the Outputs only. Next, it will be the inputs, and that is a bit of a new territory for me, because I played way too little with inputs in general. This entire 100 IO's project, partially its big reason, is built for testing and learning all sorts of inputs. I hope I will get to that and soon enough.
Thank you for reading. Romania, end of communication. Haha
