Discuss What is this box in my house in the UK Electrical Forum area at ElectriciansForums.net
I have a box in my bedroom, it's next to the mains which leads outside, u side there are green grounding wires, basically green wires, and there's a big metal plate. I keep getting shocks in my bedroom
As above, we would need a photo. When you say you are getting shocks in the bedroom, is this when you touch the 'green box/plate' thing?
If you would like our help please refrain from making rude assertions.
A picture paints a thousand words. If you're not able to supply a picture, please just say so.
Your trying to tell me to take a picture of something that could be protectionally dangerous, I'm good at other sciences just not electric science. Lol and indeed it does but it's not exactly anything more than what I've said.
Lol
Lol
Yeah just a photo. It can be taken from a few feet away don't worry.
Need one of these or a photo would be better
This is going no where without a picture
If you cannot show a picture then we can be of no help. If you are receiving shocks then seek the services of an electrician.
Think of the description I understand you may want to be precise but just a general thought will do, a wooden box with a mushroom metal plate that goes into the ground with ground green wires ?
These shocks you are getting - are they when you touch something?
It's OK lads, just remembered where it was I left my teleportation prototype. Gaz - if I DM you my address can you post it back?
Reply to What is this box in my house in the UK Electrical Forum area at ElectriciansForums.net
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I had done this about 30 years ago, and, IIRC, it was a series of boxes, Romex coming in, and Romex coming out, one in, one out, each box, except...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
