Discuss What size cable is this? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can anyone tell by just looking what size cable this is ? It’s not written on the grey outer armour
prfobably imperial 7/.044 or maybe 7/.052
50541
I've pinched this from a site.
Should give you a good idea of what size cable you have.
Then again yours is stranded... :(
I’d say 6mm with a 2.5mm cpc at a total guess
I agree, although I don't really approve of guesswork in electrical installation ;)
Or 7/036, with a 1/044 cpc,
Don't think it is, because it says BASEC down the side and they didn't exist until after metric cables came in.
Reply to What size cable is this? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Hi , I’m going install a commercial 450mm extractor fan , what size and type of cable should i use ?
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Hi what cable make and size would be needed for hikvision cctv cameras 2.8mm model number DS2CE72KF3T-E picture provided
