Discuss When does labelling have priority over colour coding?? in the Commercial Electrical Advice area at ElectriciansForums.net
Just in case you are colour blind. Lol.Discuss! This is a Daikin ASHP compressor, as delivered and prior to my install....
The labels take precedence. They're more informative. Until they fall off of course. Good to see they're heat shrunk labelled.
OKaaaayyy..... so now, when the same manufacturer, has an additional piece of equipment that connects to this same device, also 3ph, but the dangly flex DOESN'T have markings.....The use of the word unambiguous is only in the bits that refer to an interface between old and new colours.
I'm not sure what you're asking me to prove?
The labels have been applied by the manufacturer and as such could be deemed to be part of the manufacturer's instructions.
In any case, if we're talking about using black as L3 and grey as L2 there is nothing wrong with this as long it's the same at both ends.
I think you would give the labels priority in this case. The conductors can be any colour as long as they are labeled correctly, the phases are Line 1 Line 2 & Line 3. Not brown, black and grey..OKaaaayyy..... so now, when the same manufacturer, has an additional piece of equipment that connects to this same device, also 3ph, but the dangly flex DOESN'T have markings.....
My point is that table 51 doesn't stipulate a priority of columns, and 514.3.1 actually specifies colouring first AND/or alphanumeric.
For all we know this could just be the semi-furloughed factory worker not paying attention. I've another two units to compare it to, when it's not raining and I've taken the covers off!
Agreed if this was just a simple motor rotation issue, it isn't in this case as there's all sorts of complex electronics involved within the compressor unit.I think you would give the labels priority in this case. The conductors can be any colour as long as they are labeled correctly, the phases are Line 1 Line 2 & Line 3. Not brown, black and grey..
You should always check the rotation of a motor when you 1st turn it on anyway, even if coloured and labeled as you would expect.
Yep - also my first thoughts!i'd be wary and firstly think that some oik of a 19 year old with his mobile phone glued to his top lip had f*ckedup.
It could lead to future problems, also.
I'd be getting it checked with the manufacturer.
I do a lot of work for a fish & shellfish company, very quiet since the turn of the year but that's another thread. I'm forever changing pumps, I just go by the labeling, never look at or notice the colours unless there's no label. It's normally u v w but also l1 l2 l3 or just 1 2 3, I wouldn't think to contact the manufacturer, these pumps come from around the world and I wouldn't know where to start with that one and lifes too short. But as I said earlier, I always check the rotation.The order of colours and labelling does not follow normal convention and would make one wary that some kind of cock up has occurred and would be checking phase rotation/colour down the line for my own confidence in working on whatever it is you are working on.
All well and good DW, this doesn't really need saying, but I'd be interested to know how you would connect the compressor in the OPs photo and what dead tests will identify phase conductors.-Incorrect labelling kills people with no electrical knowledge as the public rely on it to be correct when switch off circuits etc..
-Incorrect colour coding kills electricians who should know better due to complacency and skipping the appropriate tests that would verify the correct colour code.
That is why in my opinion.
Although my comment was just jovial the markings in this particular case are irrelevant because the phase rotation of the supply cannot be determined by the manufacturer of the compressor, those markings shouldn't be applied at all imho and may lead to incorrect wiring and possible less experienced sparkies walking away expecting the motor to be going the correct direction and in fact it could be going the wrong way, this is applicable regardless which order the L1 L2 L3 is marked up.All well and good DW, this doesn't really need saying, but I'd be interested to know how you would connect the compressor in the OPs photo and what dead tests will identify phase conductors.
Change the other 10% around and then swap the supply rotationOK, so I was on hold to Daikin tech for so long that I actually read the manuals.... hidden in the VERY small print of the fuse/isolator schematics that we'd normally all skip past it does actually say Br-Gry-Blk - on all devices - not just this random one that I found labelled. So had I not been paying attention ? then I'd have inadvertantly wired about 90% of the plant room phase reversed for the kit that's in it.
Make of that what you will..... (but I'm not impressed by Daikin!)
Reply to When does labelling have priority over colour coding?? in the Commercial Electrical Advice area at ElectriciansForums.net
