Discuss Where to fit washer in the Electrical Appliances Forum area at ElectriciansForums.net
mikedan
Sorry, it may be trivial question but where and which direction to put washer in this lamp? Please see the attached image. Firstly is the washer in the correct position? Secondly which direction washer's teeth should face up or down?
It’s fine where it is. The teeth work both ways.
Simply put, as you tighten the nut on, the teeth dig into both surfaces and stop it from coming loose easily.
Just needs to be finger tight. No need for a spanner or anything.
Rare to see a washer on those type of lights , its just usually a dome cap nut thingy which i just put on finger tight then pinch it up with a small spanner maybe 1/2 a turn. They are literally just to hold the lid in place. As above if you go mad with a spanner you will bust the lid
Never meant " go mad with a spanner " DD you must know what I meant, if ot then you aint the DD I'm used to dealing with.
I was just pointing out that the dome nut only needs to be 'pinch' tight , small nip with a small spanner
Reply to Where to fit washer in the Electrical Appliances Forum area at ElectriciansForums.net
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
Hi all. I have a G40PSH (Greenworks 40v Long Reach Cordless Hedge Trimmer) which I have taken apart before to sharpen the blades. Only this time...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
where do i start , a customer asks me to have a look at thier old swann cctv system which was left by the prev owners . some cameras are not...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
