Discuss Where would you use this tool ? in the Electrical Tools and Products area at ElectriciansForums.net
In the wholesaler the other day I saw with the volt sticks one for picking up magnetic fields, where would this be used ??
Contactor / relay coils to give an indication as to their opperation, further checks may be required, but like the voltstick, quite good as an early indication that requires further investigation.
didnt see a picture but this is a mag probe they detect a magnetic field.
they were handy for checking coils and solenoids and motors.
they had an attenuator ring to weaken the ambient field of residual magnetism
this is what you may have been describing, low cost test device consisting of a reed switch, battery, and LED
Reply to Where would you use this tool ? in the Electrical Tools and Products area at ElectriciansForums.net
Hello everyone. What tool would I need if I were to work on a construction site doing containments? Thank you
i am looking to do some ESD testing on some electronics at home, where can i pick up a ESD simulator gun without a company
Good evening all. I have a couple of learners with hypermobility issues - which causes their hands to be sore after a day in the workshop. Has...
Register your Klein Tools online today to access tool details and protect yourself against tool theft! If you own Klein Tools in the USA or the...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
