Currently reading:
Which cable rod set to buy
Discuss Which cable rod set to buy in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
Hi all,
Title says it all really, I'm looking to buy a set of cable rods and looking for recommendations from those more familiar with them. I was looking at something like the below but TBH not sure what the difference is:
Super Rod Cable Rod Deluxe Set - https://www.NoLinkingToThis/p/super-rod-cable-rod-deluxe-set/33980
Or
Super Rod Cable Rod Set 6Pcs - https://www.NoLinkingToThis/p/super-rod-cable-rod-set-6pcs/81513
Main reason I need them now is to go across a ceiling void but happy to spend a bit more for future investment.
Let me know what you guys recomenend and that would be much appreciated.
Thanks in advance,
Martin.
Oh no! Now you've got me looking, I've spotted that they do a carrying case to keep your accessories together with your rods. Looks like I'll have to get one.
Who says I'm a tool tart?
Super Rod Carry Case 1220mm - https://www.NoLinkingToThis/p/super-rod-carry-case-1220mm/58774
LOL, its addictive, whats the reach of these things would you estimate?
Across a surface, perhaps with small obstacles, the reach is many metres. You just push it away, adding rods as required, and flick it over obstacles. You can get a sort of 'glider' end which helps to get it over stuff and stops the end digging in. Over a void or major obstacles, you need to use the stiffest rods (black). You'll get several metres before they droop too much. Sometimes you need several stiff rods with a droopy one on the far end to drop through a hole and allow a cable to be attached.
If there are any electrical trade shows on by you soon, then go along as super rod are often present with very very good discounts. Just avoid ebay as far too many fakes on there, amazon less so but only buy from amazon not 3rd party sellers.
I am just coming to the end of my second set of these (in around 8yrs I think): Cable Access Kit 10m - https://www.NoLinkingToThis/p/cable-access-kit-10m/82483
Always found them ok to be honest. They last a good while. Only seem to break at mid point if pushed. For house bashing they defo do the job, and don't really see the need for different levels of flexibility for that purpose. In a different setting then flexibility may be an issue and really useful to have, but for domestics they are fine.
I recently got some of the shorter 300mm rods (not from the links) as I thought it would be useful to have a few in my bag to save traipsing to the van. They were carp and constantly broke off at the juncture between the brass ends.
I have found the most important accessory to have when fishing is the hook. Most other bits like the cable socks and eyelets can be fashioned easily enough.
ok I bought Super Rod Cable Rod Mega Set - https://www.NoLinkingToThis/p/super-rod-cable-rod-mega-set/44025
and have used it several times and not been disappointed ...
until.....:anguished: one day going from one back box into another. I was feeding a cable into a small knockout gap. I had to use a long tie wrap as it was more flexible .
It was a gyproc wall and I was feeding into the rear of one box to another the super rod wasn't flexible enough to get through the gap and then along and back through the knockout.
so may I suggest that you also buy a long tie wrap to add as part of the kit:grinning::grinning:
all joking aside its saved me hours of frustration having this kit.
i got a set of super rods. also a cheap set (£7.99 from aldi). the super rods only come out where ther is no chance of snapping or losing. for most domestic work, the aldi rods are used.
I'm glad you said that Tel, I have an Aldi set and a Superod set. Was a bit embarrassed to mention the Aldi ones but for most jobs they're actually alright!
course they are. onlytool tarets insist on the £60 super rods, then moan their bollox off when they get stuck in a void ( the rods, not their bollox)
Reply to Which cable rod set to buy in the UK Electrical Forum area at ElectriciansForums.net
