Discuss Which is the active terminal in the UK Electrical Forum area at ElectriciansForums.net
hi can someone tell me which is the active connection on this wiring diagram
I'm no expert on commercial stuff but it looks like some kind of motor diagram, is it a terminal box with links in, looks like you alter the links to get it to spin the other way,
The two wires with the squigly line denote the input so to get it to go clockwise you connect between Z1 and U2 and if you want it to go anti clockwise you connect between V1 and V2 after moving the links. Not sure what you mean not active connection either but its AC so the polarity shouldn't really matter.
I could be way off the mark though.
As above, from your other thread the motor is connected for clockwise so the mains goes to Z1 and U2.
Reply to Which is the active terminal in the UK Electrical Forum area at ElectriciansForums.net
hi Can anyone tell me where to wire the active and neutral wires to in this single phase electric motor
Hi All a commercial office has a back up generator where can i find schematic to see how it is activated how are they normally wired for...
Lou submitted a new resource: Aclara SMETS2 Single Phase/SMETS2 5 Terminal Meter Manual - The manual for Aclara SMETS2 Single Phase/SMETS2 5...
Hi I have inherited a compressor with a single phase motor but its been stripped and I need to fathom out what's what.. I don't know if it even...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
