Discuss Why are proving units so expensive? in the Electrical Tools and Products area at ElectriciansForums.net
Good afternoon all, my query is about proving units. Several firms make them but they all seem quite expensive is it because not many are sold as an Electronics engineer I can't see the components costing a lot or is there some other reason. As I am starting up again a proving unit is a long way down the list surely combination sales would be a better bet where you buy the Voltage tester and the proving unit is part of the kit. Brian
i always use the incoming side of the main switch as a proving unit. why buy when there's a free one there already?
Simple answer is because the scams require you to have one,thats why they are so dear.Like the nut I once needed for my van,average price of a nut about 50p this one from dealer was about a tenner,when I kicked off about the price the reply was yeah mate course its dear but you cant drive the van without it!
I have one, , got it as a freebie a couple of years ago, grabbed it on my last assessment and my assessor asked why I wasn't using the incomming supply. Said that I thought that's what they expected as I would usually use the supply. Got a sort of knowing look so I put the unit back in the bag and there it stays.
only proving unit i use is for checking that our HV equiptment is dead...!!
LV units are expensive and as already said... check against the incoming supply!
problem is you need a proving unit for your proving unit to prove that the first one is working question is the battery in the proving unit flat or are the prods faulty , i got one ,found the prods would fit through the holes great eh
Proving on the incomer is no good when there is no supply on the incomer.
In 45 years I've never felt the need to own or use one, I've always used the 3 meter system.
If you test with 3 different meters the chances of all 3 being U-S are about as high as being hit by lightning in a cellar.
However I've just been given one by my current employer so I'm now looking for the chance to use it. I think I may use my 3 meters to prove the prover just in case it's no good. And then a final poke with an earthed cable.
Reply to Why are proving units so expensive? in the Electrical Tools and Products area at ElectriciansForums.net
Martindale voltage tester and proving unit, plus lock off kit for sale. All brand new and never used. I've come off the tools, hence the sale...
Hello all, I’m looking for some advice regarding a recently broken MVHR unit in my flat, model Heatrae Sadia Advance. The unit is out of...
I have worked in the electrical contracting industry all of my life since leaving school over 50 years ago. I started my own electrical...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
So I’ve managed to sell somethings and decided to buy a voltage tester and proving unit. I’ve seen this on eBay...
6K
