Discuss Why are wall chasers so expensive in the UK Electrical Forum area at ElectriciansForums.net
I've been looking at wall chasers, I really can't work out why they are so expensive. They seem to be a £70 angle grinder with a dust extraction shroud. Am I missing something?
How about this one? Don't know how long it would last but it's guaranteed.
Wall Chasers | Building Equipment | NoLinkingToThis - http://www.NoLinkingToThis/c/tools/construction-tools/cat830800?cm_sp=managedredirect-_-powertools-_-wallchaser
I mainly do industrial control work but thought one would be handy for re-wiring a house we have bought but was quite surprised at the cost. I do love a gadget but not sure I'd fork out £500 for something that's a bit of a 1 trick pony. I've learned the hard way that buying cheap tools always seems to end up in frustration and costs more in the long run.
Has anyone used the Sparky branded ones? They seem a fair bit cheaper. It's for a full house, rental seems prohibitive too. Like all tools you normally wonder how you managed without once youve got one.
You get what you pay for...................... electric tools to help you work less and faster ............. or manual tools and drive yourself into an early grave?
I have an Erbauer. I've used it on a few small jobs. So far, so good.
I've got a Bosch 4.5" grinder with the extract guard pretty much dust free chasing for about £70. Also the single blade gives you much better control.
I fit 5" erbauer disc in it to give 30mm cutting depth.
I've the Metabo one, have used the Titan, found it heavy and cumbersome to work with in comparison.
Metabo or Makita used to be the 2 options I recall in my early days, Aeg made a really good one, more powerful motor too. No longer produced.
The time saved, neater tracks for patching in, the vast reduction in cleaning up afterwards makes them worth it imo.
Reply to Why are wall chasers so expensive in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
I know this is probably very simple for a lot of you, but I just can't get it to work right right. I've been close, but no cigar. I disconnected...
