- Reaction score
- 2
Hi all, first post, and pre-emptive thank you for your help.
In anticipation of redoing all of the wiring with the computer I'm putting together, I decided to add a PET sleeve to a pair of my headphones this morning. Having just spent about $500 Cdn in connectors, wires, decent crimpers, all the pins, etc. for this computer, along with way too much RGB and ARGB bling, I figured I'd better do some testing/experimenting to gain a little experience before blowing my build up out of arrogant stupidity lol. My electrical experience is limited to changing turn signals and other such tasks with my motorcycles...
Upon stripping the outer wire casing of my headphone cable, I was surprised to see that none of the wires inside were shielded. I'll attach an image here to show what I mean.
After loosely re-connecting the long end of the cable to the short part I cut where the jack is, I could not get a signal when plugged back in to my audio source. I then tried to get a continuity beep on the multi-tester I bought, and nothing gets continuity - including touching the probes to the same wire-strand just an inch apart. I tested the unit with a regular 18AWG wire, and it indeed works fine, even down to a single strand of wire 6" apart. So it's not the multi-tester or the setting I used.
So now I'm concerned that I may not have the knowledge to to re-do all of the wiring with my computer. To be fair, the wiring from my headphones is strange to me, as noted because none of the internal wires are shielded. And near as I can tell, most of the RGB and PWM fan wiring I'll be modifying looks like 'the normal type' of wire, whatever that means.
So, if I may, a couple of questions.
1) Why can't I get any sort of signal from the attached image? I'm guessing I may need to find another cable for my headphones lol?
2) what sorts of preliminary advice might you have to help me with the computer wire re-wire? I can expand on what I'm doing if anyone wishes to help me out here
I'm hoping to be able to participate in the forum over the next few weeks as my computer build moves along...
Merci
Shawn
Merci
Shawn
