Discuss Will a Loadstar MCB fit into a MemShield2 board? in the Canada area at ElectriciansForums.net
ringer
I need to upgrade a MCB in a Memshield2 DB from 16A to 32A next week. Seeing as how most local wholesalers are shut between xmas and new year, looks like I only have Tradepoint and Screwfix to choose from as suppliers in this time period. Screwfix do a Loadstar 32A Single Pole MCB at the required SC rating of 10kA. Will this fit the Memshield board, and do Loadstar make a good/reasonable MCB? I have not used Loadstar before.
hi ringer
really not sure about loadstar, but i think moeller or contactum will fit and from memory rs sell moeller and i think they do next day.......but not sure with all this snow?
hope this helps
regards
gary
just had a look on rs and they do memshield2 mcb's
Reply to Will a Loadstar MCB fit into a MemShield2 board? in the Canada area at ElectriciansForums.net
Hi, do Eaton Memshield mcb's fit previous version of Eaton split boards code (EAD32b) for example?
Hi. I'm being tasked with installing an electric shower into a property that was built back in the 1980's. The main consumer unit has only 4 ways...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hi all, Newly qualified electrician here who is in the process of re-wiring my own property. I have recently converted my old CU (if I can call...
Hello all. 17th edition sparky here, but not been on site for the last 3/4 years (had a bit of an accident). Just bought a house with a 16mm 3...
