Discuss Will this old switch have asbestos in it? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
My customer has just moved in and wants to make sure the electrics in the garage are safe. I have only carried out a pre-works visit so far and noticed this old MEM switch.
I believe it to be the isolation switch for all the garage electrics. Will it have a fuse inside it? Also, is this likely to be an asbestos lined fuse?
Thanks everyone. I expect it will be getting replaced, so it's good to know its likely to have the asbestos lining.
I have only had to remove one fuse box before that had asbestos. It's currently hanging up in my shed with a skull and cross bones drawn on it so I recognise any similar in the future. I may do the same with this one. If not, would the local recycle centre take it or would it need to be something more specialised?
If it does contain asbestos then this is deemed hazardous waste. What is your company procedures for this.
As others have said it wil judt be flash pads if theyre even still there. The unit is a 4 way MEM CU. Speak to a local asbestos company. Im friendly with a few around here. They'll ususlly bag them up and take them away for not much coin at all in accounts of it being such a simple job.
As others have said though ive been sent / bought plenty of this gear (im sad i know) on ebay etc !
The age of this ISO was around the time when asbestos was the popular material of use.
If there’s a wire fuse inside it’s more than lightly that they’ll be a small white pad fitted.
From the picture it looks like it’s ready for an update.
Also remember that unless you break Asbestos into fibres and take the obvious precautions with ventilation etc you should be fine.
Reply to Will this old switch have asbestos in it? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
I'm after advice on how best and safely to do a friends Fuseboard upgrade. Current setup is a Wylex 6 Way board with MCBs of 2x 6A, 2x 32A and 30A...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
