customer turns the cooker off not by a 45a cooker switch but by a fused spur that had 3a fuse in it
Find out who did this and get his name and any paperwork on here will you,,,
Oh and some more photos,,,
Is that the remains of the anti tilt fixing I can see of the floor :-) Some kind of brown sikaflex maybe.
i was called to look at the cooker as it didn't work and kept blowing the trip when turned on,pulled cooker forward and saw this, 1st thing do get camera out, wasn't told which company fitted it yet
So what type/model of cooker is it and where is the gas pipe going?
Bit of a rough job. If he'd have smoothed the entry point a bit to get rid of the rough edges it looks like it would still maintain the IP2X rating required for the connection. But what "electrician" would use a point with what looks like an obvious 'crack' running from the earth pin to the top right hand corner? Thats got to be an obvious failure ......
Tonto
It would have been a laugh if you had opened this thread with
"Heap big cooker cable in busted plate Kemo sahbee"
This is hands down the worse I've seen on here so far, wouldn't the cooker have come with a plug if it was meant to be plugged into a socket? Like a microwave or kettle? Come on FFS...
