Discuss Wire Naming Convention in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rasahv
Hi All,
I'm trying to come up with a proper method of naming cables in our machine.( we develop vending machines.)
Currently im using the following structure for cable names:
Host-Target-cable Type
for example: IPC-NAC-D ; which is Industrial PC - Note Acceptor - Data Cable
But I believe there should be a more standard method of naming cables in the machine which can provide more information. I need these names to be printed and put on the cable at both ends.
Do any of you know a standard way for naming? Any suggestions or experience?
Thanks in Advance...
Never known cables to be labelled, only seen them numbered or counted off against pins on the connector and both referenced against either the drawing or O&M manual
Reply to Wire Naming Convention in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
Hello I have a question switching the above central programmers. I seem have a few more wires than other examples I’ve seen online. For instance...
Hi All Struggling to install a bog standard light switch due to getting confused by different coloured cables. I'm an avid DIY but never had...
