- Jun 2, 2018
- 486
- 354
- 101,238
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Anyone have a set of these or similar?
I have a set of these ones...
www.screwfix.com
...but like the idea of being able to strip the cable head on so as to be able to strip more of the outer sheath when a cable is already inside a backbox/fuse board.
The ones I have leave quite a bit on as you have to have the strippers sideways for them to work meaning more space required.
C.K Wire Stripper 10 1/4" (265mm) - Screwfix
Order online at Screwfix.com. For stripping flat or round cable and wire. Features an integrated wire cutter with micro-adjustment knob for stripping wires smaller than 0.2mm², crimping jaws for insulated or non-insulated terminals and an integral stripping length stop for consistent results...
