Discuss Wiring Heaters to thermostat. in the Commercial Electrical Advice area at ElectriciansForums.net
Hi all! My current dilemma:
What was three small offices is now one large one. So I have x3 DB's feeding x3 electric heaters on their own timers and built in stats. I need all 3 heaters on a single stat and timer to operate together and be tamper proof.
My thoughts are to stick all 3 on one 25A circuit, feeding the one thermostat with timer (password protected), that switches all 3 rads via single phase 25A 3 pole contactor. Any other recommendations?
Would the built in stats affect the operation of the single room stat?
Any help much appreciated.
Do think of some redundancy if stat fails , cold drafts past stats.
--2 stats in different locations minimum ?--
( Time ration heating as well ... stats if it ever gets too warm ? )
I'm not suggesting in series , but not having all eggs in one basket. Similar to Robs strategy.
If premises are large , air flows un-even ,local conditions will vary.
Dave meant the stat switching into the contactor coil will be in series with the integrated stats in the heaters.
I understand what you are suggesting too.....having 2 stats in parallel controlling the coil so that if either closes then it will bring on the heaters (if internal stats are closed).
OP, why not just have the password protected timer controlling the contactor and leave the heaters in place with their integrated stats. They will only then operate in the times permitted and the people in different areas can have it how they like it
Ok thanks all so far. I've done a wiring diagram for the proposed set up. Could someone have a look to see if all looks ok before I put it forward?
  • Heater Proposed Wiring Diagram.pdf
That's fine, thanks for pointing out the obvious mistake with the supply line to A1, think I've got it now. In regards to fusing though, it would just be a fused TB in line with supply and timer right, to protect the control circuit?
Reply to Wiring Heaters to thermostat. in the Commercial Electrical Advice area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Evening all, Have been asked to wire one of these into a heating system that has no separate control (or valves) for HW & CH. Customer is going...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
