Discuss Wiring led spotlight bar in the UK Electrical Forum area at ElectriciansForums.net
djp
I have a 2 led spotlight bar left over that i would like to stick some flex and a plug on instead of wiring into the lighting circuit. The bulbs are 5.5w each.
Am I ok using some 3 core 0.75 flex and a 3 amp plug that I already have or should I be putting a 5 amp fuse in the plug with that cable?
Cheers
Cheers
Will the connections at the light fitting be accessible without a tool or key? will they be enclosed in other words?
You need to consider safe cable entry and strain relief as well. The fitting is probably designed to be permanently fixed to a solid surface so probably won't provide this.
Any photos?
Reply to Wiring led spotlight bar in the UK Electrical Forum area at ElectriciansForums.net
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hello all, I'm replacing a 3-bulb spotlight with a standard BG ceiling rose but upon connecting, the light won't turn on; the problem is, I can't...
6K
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
